Restoring a Turntable Dustcover
pustelniakr
Silver Miner at Large
I just completed my first attempt at polishing out the scratches on a turntable dustcover. I picked the least expensive TT in my current inventory, yet the most damaged (no gouges, but enough scuffs and scratches to be almost translucent). It turned out so well that I have been requested to post it here for others to benefit from. The process involved supplies that I obtained entirely from my local hardware store (Ace Hardware), to the tune of $32 US. I have enough of all supplies left to do several more turntables, which I fully intend to do, now that I have found where to concentrate during the process.
I found the process I used at the following link (I will quote it throughout and add my own comments): http://www.theturntablefactory.com/cover.html
Please note that I had to rework all surfaces, inner and outer, to do this job.
Here is the 'before' pic of the candidate (a Pioneer PL-400):
Rich P
'After' Pic (Results of the Process)
Here is the unit after the dustcover and the rest have been fully sweetened up and is now ready to move (already got a buyer). The process took about 6 hours of mostly elbow grease. The process would complete significantly faster with power tools, but this time, I wanted to get a 'feel' for the whole process.
Here's where you decide whether the process is worth your further consideration.
Rich P
Dust Cover Starting Point
Here is where the process starts...
This puppy was in pretty bad shape, eh?
From this point, I simply removed the hinges, washed and dried the cover, and taped over the Pioneer logo with aluminum duct tape (otherwise the logo WILL be removed).
Rich P
Post-Steel Wool Phase
Original Process said:
1st...0000 steel wool over the worst scratches (the whole cover if it's THAT bad).
This is what the cover looks like after the steel wool treatment. I deviated from the original process, in that, I did all surfaces, inner and outer, because of damage all around. Scary huh?
Rich P
Post Scouring Powder Phase
Original Source said:
2nd, under running water, enough Comet to be almost a paste and a sponge over the whole thing.
Here is what the cover looked like after the scouring powder phase. Please note that modern 'Comet' is without abrasives ('scratch free'), so I had to substitute 'Bar-Keeper's Friend'. I think that the abrasive is pumice, but I could be wrong here. Running water would keep washing off the active ingredient, so I settled for keeping the slurry the consistency of used toothpaste. Some light improvement can begin to be seen here.
Rich P
Post-Rubbing Compound Phase
3rd, Automotive (DuPont) rubbing compound (preferably done on a damp electric buffing wheel.This step will take about 15 minutes, give or take (when done by hand), depending on how much elbow grease you use. You can proceed to the next step when the cover is once again, transparent and somewhat shiny. Wipe it off with a very soft cotton rag.
Here is the cover, after going after it with rubbing compound. Dupont was not available, so I used the Turtlewax brand. My arm is getting tired.
Rich P
Post-Polishing Compound - Pass 1
4th is Automotive (DuPont) polishing compound, again best with a buffing wheel... This step will also take about 15 minutes (when done by hand), and the cover should be totally transparent, pretty much scratch-free, and very shiny. Only then should you wipe clean with another soft, clean cotton cloth.
Here is what the cover looked like after the first pass with the polishing compound. I took two passes, since more work appeared to be required after the first pass. Again, The Dupont brand was unavailable, so I used the Turtlewax brand. My arm is really getting tired now.
Rich P
Post-Polishing Compound - Pass 2
Here's what she looked like after a second pass at it using the polishing compound. Barely perceptible difference from pass 1.
Rich P
Post-Cleaner Wax Phase
5th is Meguiars brand Automotive cleaning wax (It's a paste wax & slight compound in a red can). That can be applied by hand with the sponge that comes with it. I do the top AND the 4 sides with it. Rub it in good,(about 5 minutes) then clean off with yet ANOTHER clean, soft rag!! Keep in mind that the more elbow grease that you use in each step, the better the job will come out. You'll never get out the deeper scratches, but depending on how bad it was when you started, it should improve immensely! I've had covers that had become translucent that I was able to bring back to transparent...and shiny, too. The 6th and last step I recommend is to spray the inside with Windex, AND a shot or two of liquid spraywax, letting the two liquids mix together (Pledge or equivelent), use another rag to wipe it all up. Do the same for the outside of the cover when the inside is dry. The reason for the both liquids is that spray wax by itself streaks, and Windex by itself scratches. Put the two together, though, and you get just the positives!
Edit: Before using the Cleaner Wax, I have added a stage using Meguiar's "PlastX" (Clear Plastic Cleaner & Polish). I find that it provides a better polished substrate for the Cleaner Wax stage, with an even better finished result.
Here is what she looked like after the Meguiars Cleaner wax (I used the bottle as the can was not available). I stopped at this step, since it looked so nice I didn't want to push it. My arm is about to fall off at this point.
This was my first attempt and I believe it turned out real nice. The results could have been even better with more uniform work in each area, and more time at each step, which I will do next time, along with a buffing pad on a palm sander with a wedge foot, and lots of soft cotton rags and buffing pads (easy as she goes on the pressure and the let the tool to the work, and lighter pressure as you progress from step to step. Each phase should completely remove the evidence of the phase before, for best results.
Enjoy restoring your own dust covers and other plastic surfaces (like CT-F9191 cassettte doors...)...
Edit: Look here for a reference to doing this job using the Black and Decker Mouse: http://audiokarma.org/forums/index....-turntable-dustcover.42972/page-2#post-432805
Rich P
What a great job! Joel at the Turntable Factory is a fount of knowledge, and it really helps to see what happens in the real world when one of us tries the instructions.
Nice pics of the dustcover restore. Great job. :banana: :thmbsp:
Although I knew what to expect after the first couple of steps, it's good to let the newbies know what to expect so shock dosen't set in when they do it.
kerozene said:
Thank you, I'll tackle my Denon now... mmm... let me rethink this... first I'll try on the Pioneer.
Go easy. Try on a cheap item first, as I did, to get a 'feel' for how much juice to use, and what kind of strokes work, and which ones will be hard to get out in the next phase.
I intend to go after a couple of Pioneer PL-630s next. Now that is scarey, since they are my high rollers. Easy as she goes now...
P.S. I'll be gentle with her Mike :)
Rich P
oh my gosh....nice job....but you freaked me out.
what a nice job...and i will use the same technic to clean my technics TT dust covers, but you're freaking me out man.... you're like sick psycho audiophile...lol. thank you for your great step by step instructions. they should hire you at those factories.
Nice job there. I tried it myself a while back on a technics cover, I only did the outside and it worked pretty well but I don't think I was as carefull as you with the polishing steps. I got the info from the same link as you put up. You have inspired me to have another go and do the inside as well.
