I'm pretty much a tube noob, so I'm not sure what to make of this.
I got a nice Dynaco ST 70 with a VTA low gain driver board, SDS PS cap board, no selenium.
It's been running superbly until tonight. I had it on, then turned it off for about 40 minutes while I ran an errand. Came home, turned it back on and got a little zap sound from one side. Then about the time I started towards the amp, the right front output tube went up like a Roman candle. I got it shut off almost immediately.
OK, the output tubes were JJ EL34, which I gather ain't the cream of the crop. Would this be unheard of for one of these?
Was 40 minutes too little time to restart?
The amp appears undamaged underneath, should I pull an output tube from the other side, bias it, and see if it goes up? Or just get a new quad of tubes, I kind of want to give some KT77s a whirl, anyway, but not if there's an inherent problem that'll smoke the new tubes.
Thanks for any guidance.
