spacelord
Great Googly Moogly
hey guys,
I have seen in Echo's posts (the great wizard), where he has talked about a procedure where you can bypass the selector switch on the 9090 so that the dial lamps stay on when the unit is in any other position besides the FM mode.
How is this done???
I assume the power is removed from the selector pot (wherever that may be), and then do you energize the lamp circuit with a jumper from the 6v tap of the power supply???
I do not have a schematic of the 9090, so DETAIL in the description of how to do this would be greatly appreciated.
Thanks ---Chris
How is this done???
Thanks ---Chris
