oldtubes
I puchased a Pioneer SA-8500II today at the flea market, it blow the right channel power supply fuse. I found that one pair of the four output transistors are shorted. The outputs are NEC B617A/D587A, these transistors have an odd case with mounting tabs on each side. I have tested it with just the good pair installed in the right channel. The fuse does not blow and the amp comes out of protection mode. DC offset is 1.7mV left and 2.0 mV right, so the amp seems to be healthy if I can only find some new output transistors for the right channel. Does anyone have an idea on what could be substituted for the B617A/D587A? The data sheet I found on them states they are 70W, 6 amp, 120V, hfe 40, and ft 17M.
