No ladders or children were harmed in the installation of this antenna!
I installed the Radio Shack $25 FM antenna (really an Antennacraft FM6).
Used the eaves mounts. My big kid (6-foot +) held the extension ladder while I drilled holes and bolted on the brackets. My very slim daughter got up on the roof and held the antenna while I tightened the brackets. Only minor eye rolling on her part.
And I didn't fall off the ladder.
Note that I actually remembered to buy a ground rod. I have the ground wire attached, but not yet anchored to the side of the house.
And a "drip dip" in the cable so that water will not run along it and drip into the attic, but rather off the bottom of the dip.
About the ground wire. If anyone really thinks that in case of a lightning strike, that the lightning bolt will follow that wire, and carry 8 gazillion megawatts, you need to study up on lightning. But what the wire will do is lessen the chance of a strike. That is the way lightning rods work. They drain off the charge in the earth into the air, lowering the potential. This is what happens when you see "St. Elmo's Fire" or a glow around ships masts or the ends of antennas during a storm.
Oh well, that's all that can really be done. If we get a hit I'll just buy new gear.
No report on performance yet. By the time we got it up it was too hot in the attic to make the connection.
Right now I have the antenna aimed halfway between two distant cities that are about 40 degrees apart. The antenna should pick up both pretty well. :scratch2:
My plan is to set the tuner to a station in one of those distant cities, use my cell phone to talk to my son, aim the antenna for best signal. Then have him switch to another station in the other city, find the best direction for that station, then aim halfway between and see if both come in with acceptable levels. If so, then I won't need a rotor. :thmbsp:
Tomorrow, very early, skinny daughter goes up in the attic to disconnect the Godar and connect the outdoor antenna.
Then
