efhjr
Can you be more specific?
OK, now that I've got an idea about how to use my MI-3 (thanks folks!), let's move on to my MC30s.
Here they are:
They'll be fed by my C28, and they will power my Klipsch Cornwalls. And here are my questions.
Speakers -- I'll feed the Cornwalls from the 8-ohm taps. Do I use the COM or GND terminals. What's the difference?
GAIN and HUM ADJ knobs -- how do I set these? I'm assuming I'll do primary volume control via the C28.
Variable damping knob -- the amp on the left has a higher serial number, and it also has this switched potentiometer which the older amp doesn't. What is it, and how do I set it?
I've used these amps before and they sound quite nice (of course), but I've never used them with my C28, and I'd like to know how to best install them in the system. Thanks in advance for all your help.
Here they are:
