Today I found a pair of JBL Lancer 66 at the local thrift.
Cabs need some work, but should polish up nice.
Grille cloth has a few small snags, both badges present.
When I pulled away the grille I noticed the woofer surround was made out of some strange material. It is not quite rubber, not quite plastic. I did some searching on Lansing Heritage and read about some stuff called lansolay (I think that was what is was called), it is described as being white, brown, or yellow - this stuff is black. It has tiny, hairline cracks in it.
Can this material be replaced? Would rubber or regular foam be OK to use?
Am I going to have difficulty removing the edging from the woofer frame and paper cone?
I couldn't find much info at the Lansing site, and I spent a pretty good bit of time in there. This was the only catalog pic I could find - from 1962
Anyone else in here have any experiece with these? I assume these would be tube speakers?
herbs
