Does it run fast or slow?Too bad it doesn't keep time for a dang.
I like those 'jetson age' clocks too!
I have one of the Nelson Sunburst ones.
Very pretty. Too bad it doesn't keep time for a dang.
Insanely pricey today.
It's a defective quartz module, nothing special. Replace it with the Seiko mentioned earlier.Katalyst: It runs slow. Within a few weeks of a new battery, it's slow by nearly 5 minutes.
Granted that may be 'worsened' by using cheap meanards batteries
The single AA needs to be replaced every couple of months.
Reydel: Thanks for the link - - I'll look into that!!
I've wondered about replacing what looks like a pretty cheap movement...though I see it's 'made in chermany'.
This clock is not very old - about 10 years - and has always run slow. It was a gift, and the first one had to be returned, as the 'pointy bits' were all loose on arrival, and access inside requires tiny stable fingers.
The price HM gets for these things - given the relatively low mechanical quality (the paint job is superb) is astounding.
It was a gift, and looks amazing, so I don't get too upset about it being an 'approximate time only' clock!
PS. Spiders love to spin webs around the sunburst pointy bits...should come with a feather duster!
FWIW, I also have the Eames 'Hang It All' coat/hat rack thing - another screechingly overpriced, and frustratingly un-functional design (stuff just slides off those 'balls' - should be called 'Fall It All'!). But I manage to make it work for me
It was designed for kids, apparently. Makes sense.
Thanks again!
I have one of those German "electronic" germanium transistor clock mechs. Interesting things, could probably use a cleaning and lube. Timekeeping is easily adjustable and they last about forever if not abused.Looks like a bog-standard quartz movement to me. Boring things, for the most part. Did find a neat Ajanta 7606 wall clock (made for the Indian market?) which uses their "Real Silent Sweep" movement. Looks just like an electric clock when running. Need to find a place to hang it, and I'll take some pictures.
Here's a wall clock I did take pictures of:
Looks to be from the late '60s/early '70s. Made by General Electric, according to the logo on the dial:
However, when you look around back, instead of the expected Ashland-sourced Telechron-type movement, you see this:
An ATO-style electronic movement!Made in West Germany, along with the rest of the clock, according to the sticker:
Here is a picture of said movement:
Tends to run rather fast, for some reason. Need to figure out how the speed adjustment on the back of the movement works:
Probably no small miracle that it runs at all, methinks. Has a funky little lever to start/stop the movement, which is nice.
Looks pretty neat overall. Wouldn't be out-of-place in an executive's office, a'la Mad Men.
-Adam
Sorry--I know this is obvious--but given the thread title I just had to..
This is a MasterCrafters Starlight Clock (No. 146) from 1959. I bought it for myself for my birthday a couple days ago.
The rate adjustment is the little recessed slotted screw thingus with the index marks. Requires a fresh alkaline 'C' cell to establish a baseline first.Looks like a bog-standard quartz movement to me. Boring things, for the most part. Did find a neat Ajanta 7606 wall clock (made for the Indian market?) which uses their "Real Silent Sweep" movement. Looks just like an electric clock when running. Need to find a place to hang it, and I'll take some pictures.
-Adam
I'm not super worried about mine. I used an (admittedly uncalibrated) CD-V700 geiger counter to check the markings on my Golden Hour, and though the meter shows a fair amount of deflection with the probe right near the clock with the 'beta shield' open, it shows much less with it closed, and next to nothing when I pull the probe a few feet away. Also, later examples (post-1965 or so) Golden Hours were produced without radium paint, according to this page, so you don't have to worry about all of these clocks.I've restored 6 or 8 Jefferson Golden Hour clocks. I had quite a fascination for them.
Then, i bought an accurate/calibrated dosimeter. Fascination instantly cured. Hotter than anything i want within my immediate biological world.
I knew that was the rate adjustment; I just had no idea exactly how far out from 'normal' it was. I also wasn't sure exactly which direction you turned the screw in order to make it go faster or slower. After some experimentation, I'm pretty sure I've got it down pat at this point, and it's fairly close to accurate.The rate adjustment is the little recessed slotted screw thingus with the index marks. Requires a fresh alkaline 'C' cell to establish a baseline first.
It'll vary as the cell drops emf. That's why a modern alkaline cell is prefer to a carbon zinc in these things. Fwiw, think of this as a slo-mo Accutron with a balance wheel instead of a tuning fork, otherwise almost identical. An even slower slo-mo version is the Kundo Electronic pendulum clocks, virtually identical to the Accutron tuning fork timepieces.I'm not super worried about mine. I used an (admittedly uncalibrated) CD-V700 geiger counter to check the markings on my Golden Hour, and though the meter shows a fair amount of deflection with the probe right near the clock with the 'beta shield' open, it shows much less with it closed, and next to nothing when I pull the probe a few feet away. Also, later examples (post-1965 or so) Golden Hours were produced without radium paint, according to this page, so you don't have to worry about all of these clocks.
-Adam
