You might consider the Sony PS-X50, 60, 65, 70, 75 series. Almost the sound of the Pioneer (IMO, at least) and it's got to be the easiest, fastest, on-the-fly VTA adjustment I've seen. The only negative is that the range of movement is not as gradual as on the Technics, nor is it marked in graduations, but I think it's still accurate enough to be repeatable. All the models are DD quartz. The X50 is semi-auto, 60 is auto, 70 is auto with separate auto and platter motors, 65 is auto with semi-biotracer arm, and 75 has the full biotracer arm. The last two can suffer from electronic failure, so just be aware of that.
