If vinyl sounds better than digital, am I using the wrong DAC?
To go back to the thread title...
"If vinyl sounds better than digital, am I using the wrong DAC?"
Taking a needle drop of your Alan Parsons Project will hopefully allow you to play that Alan Parsons via your DAC, imperceptibly from playing the vinyl. If the vinyl sounds different, then maybe start to look at the DAC as the weak link...
Which will save the vinyl from further wear & tear...
Not sure where the idea of a needledrop being definitive came from...
...but...I have cds and streaming for that...;)
All good fun sir! ...I'm off to the patio for pre-BBQ refreshments and some tunes via SiriusXM (streamed!) :cool:
Cheers!
:beerchug:
I always thought that my DAC and streamer were fine. I tried a few different DACS and couldn't tell much of a difference if any at all. Until I upgraded my speakers. Than my streaming was terrible. I guess my point is the detail and sound quality of the DAC is really dependent on the rest of the system.
New to this thread.
As a forumer that is very active on the "turntable" section of Audiokarma, i find this thread exciting.
My take on this, not only as a turntable technician and record lover, but also as an engineer who actually had to go through courses and labs covering PCM analog-to-digital and digital-to-analog conversion, my opinion is the following:
We need first to discern between CD-quality audio (44KHz /16bit) and hi-res audio (88KHz or more of sampling rate, and hopefully more than 16 bit).
And let me start saying that I think digital audio is one of the greatest inventions of mankind. However...
If we're talking about CD quality audio, this is a medium with the following characteristics:
1. It is a system that is bandwidth limited between 0Hz and (approx) 22KHz. Thus it is limited in slew-rate too.
2. The process of converting from digital to analog requires a reconstruction filter. You can do it in the analog domain, or the digital domain, or mixed, but the end goal is the same: a frequency response more or less similar to this:
That is, a filter that has an insanely ridiculous steep attenuation near 22KHz. This is the often-named "brickwall filter".
This kind of response would make any analog audio fan or even speaker designer or even amplifier designer cringe.
This means the phase near the last octave (10KHz to 20KHz) will be completely wrecked.
And i'm not even talking about the pre-ringing and post-ringing...
There are many kinds of digital (and analog) filters and filtering implementation but the goal is the same, and the result is either you wreck the phase response or you get linear phase, but then what one gets is a non-flat frequency response -- a frequency response that has ripples... Etc. You can never win. Maybe that's why some people prefere non oversampling DACs with no reconstruction filters? Well... i digress... back to our topic.
3. The process of converting from analog to digital requires an antialiasing filter, which will do more or less the same, adding more injury to the signal, that is, more phase distortions, ringing, etc.
The impulse response of such an ADC->DAC system will not really be true to the original.
The solution is obviously using a higher sample rate, in this way, the filter doesn't need to operate close to 20Khz, for example if one uses 192KHz sample rate, one only needs to start attenuating at about 96KHz, well away from the audible band. Thus the impulse response is better, phase is preserved in the audible band, etc etc.
This problem was already known in the 1970s and the main makers of pro digital gear used 50KHz (3M, Soundstream) or 50.4KHz (Mitsubishi), and if they could have used higer sampling frequencies they would've done so, sadly they were pushing the limits of what you could store on magnetic tape. The data rate of digital audio at 50KHz/16bit/Stereo was really pushing the state of the art in digital storage at the late 70s. The AES recommendation for digital audio in the late 70s was 50KHz, and the Sony and Phillips guys were aware of this when designing the CD, however they went for 44.1KHz for other reasons that can be resumed as "Better compatibility with our PCM-to-videotape systems", which used 44056Hz (later 44.1KHz) for the reason that can be resumed as "it's the maximum we can reliably record on consumer Umatic/Betamax videotape".
So, CD-quality audio was already doomed from the birth.
4. And i have not even mentioned: digital quantization distortion... only because it is a problem that can be overcome if everything is done right.
Now, let's compare to the LP record, done correctly. Brace yourselves, because I am going to mention things that the layman often ignores.
Record-to-playback bandwidth: From (about) 20Hz to about 50 (fifty) KHz. Half-speed mastered records take advantage of this bandwidth.
Antialias brick-wall filter: None
Reconstruction brick-wall filter: None
Frequency response of the system does not decay like a landslide after 20KHz; it decays gradually. Thus there is none of the phase aberrations or impulse aberrations that the CD quality audio has.
Frequency response of a very good phono preamp is within +/- 0.1dB, an excellent result already better than almost every speaker out there. And phase is kept mostly unaltered since the (gentle, 6db/octave) RIAA filters introduced at the record time are applied in the exact inverse at the playback time.
Frequency response of a very good MC cartridge is ruler flat up to at least 12KHz, some of them ruler flat to 20KHz. Most have response over 50KHz. Bandwidth of the electrical system of a good MC system is over 100KHz so there is no slew rate problem.
Frequency response of the cutting head used to record the lacquer master is absolutely ruler flat in the audible band, thanks to the use of motional feedback. A really great cutting head (Ortofon DSS 731) reaches 30KHz (at -5dB), this means over 60KHz if doing half-speed-cutting. One audiophile label claimed recording over 100KHz on a lacquer disc, btw.
There are many more differneces that can be mentioned but i'm trying to keep it short.
I also want to say, for people who think that REEL TO REEL ANALOG TAPE is the superior medium, that the direct-to-disc (direct to lp record) recording was already judged to be superior to tape recording back in the 1970s and 80s, thanks to lower background noise, absence of 3rd harmonic distortion, no frequency response "bumps" introduced by the magnetic head, etc etc. If you think a vinyl record sounds good, wait until you hear a direct-to-disc record!
The LP record, thus, is a very high fidelity medium, at least if we ignore the surface noise problems. It can even reveal the sonic signature (imperfections?) of the early digital systems, when you listen to digital records mastered from digital recording systems in the 1970s.
I have more invested in my vinyl setup than my DAC, same as many here. If I A/B a quality LP vs digital, vinyl sounds better than the same track streamed through Qobuz consistently. I've tried different DACS and have a hard time deciphering the difference like I can from one cartridge to another so I think the variables are higher with vinyl playback. For critical listening, its vinyl unless I don't have the track. My best cartridge is a Dynvector 10 x 5 low but others still sound better than digital. DAC chip is a Twin Wolfson.
Vinyl is not easy and not for everyone but I think it is still the pinnacle of music playback if done correctly with quality equipment. I enjoy all the nuances of vinyl. Buying highly regarded pressings, cleaning albums, maintaining the turntable, arm and cartridge etc. I have many friends that want non of it though and I respect that.
Now, even if you were using Hi-res audio, other things that influence the quality of LP vs "digital streaming" needs to be mentioned:
1. Many times the audio system in your computer is resampling the audio without giving max consideration to sound quality. This can be configured in some systems. So your computer is probably degrading the audio quality. Make sure you can ensure a playback system where the digital file goes straight to the DAC. (Easier said than done...)
2. Are you sure you're getting hi-res audio? There are many cases of so called "hi-res" files that are just files upsampled from 44.1KHz/16bit files.
3. Implementation of digital filters not always is done in the optimal way, for example calculations are truncated due to the need to reduce the computing power used for this, and this can degrade the audio signal.
4. Then there is the other issue, the quality of the digitizing. Did they use the original master tapes? Were the master tapes in good shape? Was this done with care?
Chances are for, a 1950s-1970s recording, that the original LP record was made from tapes in better shape, and/or with greater care.
So, in short, there are many reasons for the LP to outperform digital streaming.
However, the LP shouldn't be able to do better than hi-res audio (i.e. uncompressed 192KHz/24bit) done properly, played through a good DAC. The latter has greater bandwidth, better impuse response, better phase correctness, etc etc.
It’s not uncommon for a phono stage to deviate from the RIIA equalization curve or have elevated THD both can lead to the sensation of more defined low end compared to the typically flat and low distortion digital path and its possible your vinyl setup has some mild EQ to that euphonic effect. It’s very easy to perform high quality EQ in the digital domain to correct for room/speakers and tastes. Just a thought.
Phono stages, even the cheapest ones, have already a smoother frequency response than all but the highest-end, highest-performance speakers.
They are also fine with THD. Phono cartridges show mostly only 2nd harmonic distortion, which has been shown to be inaudible even in gross levels like 10%. Never rely only on THD, the harmonic profile needs to be considered too.
It is true that low-end response on a turntable can be enhanced due to mechanical reasons. However most often what happens is the opposite: a weak bass response. And only the truly good turntable systems, with good tonearms and plinths, give you a good, strong, well-defined bass response.
Even more reasons i need to mention:
It appears that in the 80s an often used format for mastering LPs and CDs was U-matic videocassetes recorded with the Sony PCM-1600/1610. It was ubiquitous, apparently:
Now here comes the fun part, at least what I read (was it on stevehoffmann?)...
Since in the 1980s there were no digital equalization avaliable that sounded good, whenever the mastering engineer needed to apply equalization to master the CD, he did it on the analog domain.
So when you listen to the LP you are listening to:
(analog or digital recorder) ---> analog mixing ---> PCM 1600 ADC --> Umatic tape ---> PCM 1600 DAC ---> Cutting head
But when you were listening to the CD, you were listening to...
(analog or digital recorder) ---> analog mixing ---> PCM 1600 ADC --> Umatic tape ---> PCM 1600 DAC ---> analog equalizer ---> PCM 1600 ADC (or other ADC) ---> compact disc recorder
So you were introducing an extra sound-wrecking DAC-to-ADC-to-DAC stage. This happened even if the disc was labeled DDD. In fact i found that post on a discussion about DDD compact discs, if I recall correctly.
Another problem of digital audio was that in the 1990s, not everybody understood how to do proper digital mixing/processing without wretching the sound quality. For example without working with 32 bit depth, there is a big chance you are running into rounding/truncating errors that will do horrible things to the sound quality.
And i'm not even mentioning the loudness wars!
Etc. etc.
New to this thread.
It was in the literature at the time, the issues. Thank you for taking us through it.
I know vinyl versus digital is a controversial topic, but there seems to be something of a consensus that while people might prefer vinyl for various reasons, it isn't objectively better when it comes to the reproduction of sound. But when I say it "sounds better" on my system, it's really something of an understatement. With good vinyl, I get better separation of instruments, punchier percussion, a more expansive soundstage, and above all, a more natural sound, along with the crackles and pops.
Of course, equipment is everything, I presume. I had never considered my DAC a slouch - it's a TDA-1543 model, the Abbas Audio Dac-Z. His entry-level model, but people say it compares favorably to the Border Patrol DAC and even some higher-end stuff. It's supposed to have an analogue quality, which I appreciated when compared to other DACs I've heard.
On the vinyl side, I'm running a Dual 1219 with an Empire 1000 ze/x cart and cheap stylus through the phono stage of a Yamaha cx-630. All-in-all, not a high end setup by any means but using some bargain vintage gear that would probably cost a pretty penny for modern equivalents.
Any opinions or experiences? Wrong DAC, or am I just deep into the vinyl kool-aid?
It's not analog vs. Digital anymore,it's all about the source and how it was recorded.
It's a long chain of compromises compared to experiencing the artist/s perform at their best, but it's still pretty damn awesome just to get a small percentage of that.
The problem is that a really good pressing from a well engineered master album has a lot more data than any digital format. Digital is about consistent data that is not changing and as volitle as vinyl.
That data is the data and no DAC can improve or add anything to the data that is available. Just like all albums are not created equally the same is true of digital media. You can not make up for the engineering that went into the origanal music or any remastering that has taken place.
Back when dinosaurs roamed the Earth I remeber a magazine praising early CD content in the early 1980's and the writer threw a CD into the sand on a beach and threw a record intot he sand as well. He then cleaned them and proceded to play them and was raving over the CD.
I have sleep issues and as part of my nightly routine I play the same 3 movies over and over again as background noise. I have DVD's I have been listening to each night on repeat for over 20 years. I have really bad PTSD from torture. I have worn out 3 DVD and BluRay players in that time only using them at bedtime and while I sleep. No record could ever hold up to that level of use but those DVD's are going strong!
It is true that the DAC has a bigger impact on the sound than anything else we see this when people take hi end transports and ancient CD players and A-B them then decide to put them all through the same hi end DAC and no one can tell them apart. Pearl Acoustics recently did this! His Youtube video on the results is very intersting!
While true, this doesn’t really matter for one’s comparison between digital and vinyl as the same speakers would normally be used for both and digital would usually have a more correct frequency response than a phone stage.
I think it's personal preference. Some prefer vinyl some prefer digital. But I'll say this again, the quality of the system makes a huge difference. And to listen to digital properly it can get expensive but if it's set up well, digital can produce amazing sound quality.
Well at 49000€ I expect it to sound like I have balanced cables coming down from heaven going straight into my rig.
for $49k I expect taylor swift to show up with her road crew and band. Ill settle for elvis and an autograph..
Are we really comparing mediums here? Technically none of us are listening to digital, we're just comparing the analogue outputs of the phono section, and those of the DAC.
I've invested tens of thousands in stereo equipment over the decades. Have never had a turntable/vinyl come even close to sounding as good as my current DAC/digital files front end........even on the same recordings. Bought Pink Floyd's deluxe redo of Animals, guess it was last year, that contains both an LP, CDs and Bluray, bought the SACD too. Tried the LP the other day, not even close to sounding as good as the digital versions. Maybe I've just not invested enough in a turntable front end yet. :)
I have a Cd player, DAC connected to a PC and a Turntable setup. They all sound different, do I prefer one over the other, no I listen to them all and enjoy them all. If they were cars I would say that Vinyl is like riding in a Cadillac, nice and soft, smooths out the bumps. The PC with DAC is like riding in a sports car, faster more responsive and gives you a firm ride bumps and all. Cd' player is not as smooth as the Cadillac and not as tight as the sports car, somewhere in between but closer to the sportscar than the Cadillac.
most who compare vinyl to digital really generalize too much. The better sounding source goes back and forth with each incremental increase in performance of the analog or digital gear. Also depends on the digital file size and bit depth. you may want to consider a better phono stage. The CX-630 phono preamp is ok but can be easily improved upon. You can get the EAR phonobox or Marantz 7 clones for 250-400 bucks depending on which you choose.
@paperhouse
I have not heard the entry level Abbas Audio Dac-Z, but I did have a friends Abbas 2.2SE based on the TDA1541 in my system for a short while, It sounded fantastic, very natural, maybe the most realistic sounding DAC I have heard. Granted the 2.2SE is a fair bit more costly.
