thing is do they fit...you can go up or down in value at 18kuf probably over rated i.e. 16kuf but up the voltage or go up in value and same voltage. Good quality will 'filter' the rail voltage. higher voltage capable is usually better. You can quad in 4 caps but just takes some custom mounting but 4x the esr.
hope it helps.
