Stefan Wood
I have a magi preamp that uses sylvanias 6sl7 tubes. I want to tube roll and realized I picked up a pair of 6sn7 tubes. Are they compatible or do they have different specs and it would make the sound not so good?
Got it. Any recommendations for 6sl7 tubes? I have sylvanias but open to other suggestions for rolling.
You can also get Russian equivalents.
6H9C. Mine are from the early 70s. I forget which maker.I have not heard good things about RCA, except for the red base ones. What Japanese or Russian tubes should I look for?
RCA engineers invented the 6SN7 and 6SL7, along with the 12AX7, 12AU7, 6L6, and many other tubes we commonly use. I regard their 40s and 50s production as the gold standard of American tubes, especially from the 30s, 40s, and 50s era.
Have used RCA 6SL7GT for thousands of hours, enjoying good sound, low noise, and little degradation of tube characteristics. What bad things have you heard? I know some of their later color TV tubes like the 6GH8 didn't last well, but the older designs sure did. I consider the foreign tubes to be knock offs of the genuine RCA 6SL7.. the Russian ones you can find easy enough. Japanese tubes are harder to find, the brand I referenced above is TEN - I just happened to find some of them in old gear, and enjoy them. They were sold as a discount alternative to the domestic tube brands back in the 60s.
One thing about RCA, is they stopped making consumer tubes in 1976. Sylvania stopped in 1988, and GE in 1991.. because of this actual new old stock RCA is harder to find. Something you have to be wary of with old stock tubes, is the brand name printed on the tube is often not who made it. All the big names often relabeled each others tubes, so it is common to find a GE tube with an RCA or Sylvania brand, or vise versa.
What I had heard from people who owned those tubes was that they colored the sound compared to the 5691 red bases or the Sylvanias or certain Tung Sols.
There was a post in this forum I believe from someone who owned a 300B amp and for his preamp he installed JAN Philips 6sl7s and stated that they did not detract from the clarity of the amp. I have a type 45 amp and am looking for something similar.
Here is a simple reminder: random subjective opinions are not very useful in general. If person A says tube B didn't sound good, it offers very little useful information. What was the function of the tube in the circuit (for instance someone mentioned a 6SN7 as a cathode follower in a post above; that's a very different use than a voltage amplifier)? What was the operating point of the tube? One can easily change the sound of a tube in a circuit from clean and precise to vague and warm simply by changing the operating point. It can be fun to inform others about your successful audio endeavors, but that doesn't always translate into information other users can duplicate.
