rlisin
Quad 4 life
Every few weeks (or days) someone asks about a switch to connect 2 amps to one set of speakers, and whether a particular speaker selector switch will work. Most won't, the ones that will are usually more expensive. Some are unnecessarily complicated.
The problem is that it has to be a specific kind of a speaker level switch to accommodate 2 amps. It needs to switch all 4 connections: L+, L-, R+, R- separately (no common ground), it needs to be a "break before make" type (break connection to one amp before making a connection to the other) to prevent both amps being connected to each other even for a split second - obviously it should make it impossible to select both amps at the same time, and it ideally it should not have anything else inside except binding posts, wires and a switch (no resistors, no protection circuits, impedance matching etc.).
The simplest and cheapest option is to built a switch box using a 4PDT switch. I recently built two, the total cost is around $10-20, depending how cheap you can get the switch and what type of binding posts and enclosure you use. Here's one of them. That's the more expensive one because of banana plug-ready connectors, but if you use spring-type connectors, it becomes very cheap.
Parts:
That ^ plus some speaker wire and a few screws.
I used this for enclosure:
I gutted it:
I cut a wall from plywood for binding posts connected to the switch with speaker wire.
Assembled back:
And front:
That's all. This one works for either two amps to one set of speakers, or two speaker sets to one amp. The next one I will built will have two 4PDT switches, one for switching amps, the other for switching speakers.
Parts:
I gutted it:
Assembled back:
And front:
