iloveitloud
Can 901's be made to sound the way they were intended to without the BOSE EQ? The reason I ask is that I already run a spectrum EQ, and use the EQ/base,mid,treble controls as well. With both of those systems together, there is alot of potential to boost low, and high frequencies, which seems to be what the BOSE EQ dose. The main reason for this question is that I don't want to loose the spectrum EQ, due to the BOSE EQ takeing up the tape 2(monitor) input/outputs. Also, I found a good deal on some series V's, But the EQ is not included. Thanks alot for any advise.
