OK, wrong guy to answer best, but here is the "gist":
The solder terminal K55V (only produced for a couple of years, around 1980-1981ish) is free of "The Glitch" (it's either 6 or 9 kHz, can't remember which) which appears in a substantial percentage of K55Vs of "normal" (read: prior to the solder terminal version in production, those will have the standard push terminals) origin.
That "glitch" clashes against the K77 like a train wreck, especially on certain networks and models where it's worse than some others. If your K55s have that glitch it is AWFUL and will drive people crazy getting rid of it (harsh treble).
It gets complex because a number of "normal" K55s don't have the issue, but a lot of them do, and I will certainly say that this was a large contributor to their rep as a "PA" speaker or "too harsh to handle" . In speakers with replaced networks those can REALLY show that flaw with some cap formulae.
It was a bit of a held secret of sorts on Klipsch Forum, especially before the A55G showed upon the market - people talked about it but tried not to make a big deal over it and cause the drivers to soar to $500 each, LOL. But once I rolled a pair of solder terminal K55 with the dual phase plug/solder terminal (which I bought on forum) into my Belles I became a REAL believer - that the "glitch", if present, is a MAJOR factor in sorta ruining the speaker from a truly hi-fidelity perspective. There's a newer Atlas driver that fixed this too I think, as well as the A55G which is also free of that issue and probably this "drop in driver alternative" best replacement version. But back before those drivers existed it was the "solder terminal" version of that driver that became sought after because it' a smoother driver.
And many still consider this as good of a driver as available, the AlNiCo K55V solder terminal is a pretty good mid driver among ALL of them now out there point of fact, from one who has sought the BEST of that driver as I wanted to keep my cabs original. The only reason I ultimately replaced mine was over a 50-year updating of ALL the innards so I went all new with the A55G. But the K55V solder terminal version is right up there, and oft still the best in many eyes and ears out of these as they really like the character of the AlNiCo, which is notable.
All of that to say you have the "good" version to be sure.
