Check to see if the tube filaments are lighting. That tuner uses series-strung filaments (like Xmas lights, if one is out it takes out the whole string). If none light, have the tubes tested or at least use an ohmmeter to find the open filament tube(s).
If the tubes do light, make sure you have a decent antenna connected. If so, wiggle the tubes slightly by their tips to see if you get any crackle or noise. Might have dirty and intermittant tube sockets (spray with contact cleaner). Checking tube voltages after that, and potentially replacing capacitors and out-of spec resistors.
RWood
