Just a quick project for tonight. Picked it up at GW along with a 490i receiver the other day. Checked it out and the functions seemed to work so I decided to keep it. Quick listening test showed it robbed a little detail from the music when the EQ was active as opposed to it just looping back to the amp with the EQ off. A recap of this was going to be a winter project, but curiosity got the better of me so I opened it up to see what the insides looked like. Pretty empty and not too many caps, so I checked my stock and decided a quick redo was in order.
I had downloaded the SM and looked at the schematic and noticed that some of the lytics were directly in the signal path. So, these were going to get audio, film, or UKL caps depending on value, etc. The photos show these audio path caps to be the purple sleeved ones which are Matsushita caps (Panasonic).
I've had problems with these caps in other gear so knew they were coming out, but it somewhat answers a question I posed in another thread as to what series caps these purple ones were. They're either Panasonic's equivalent of a low-leakage cap or audio cap for future reference. Anywho, after pulling them out I discovered several with corroded leads (just like in other gear) and 2 were open. So, if found in any gear you restore, REMOVE AT ONCE. They are problems waiting to happen.
Without further ado...
Before
After
Before
After
