StepheK
Super Member
As I posted in another thread, I did a video series build based off this "classic 300B" schematic that has been floating around for decades, using a direct coupled 6SN7 2 stage front end. After I got finished, did some basic scope testing and then listened to it, I wasn't impressed. Thin bass, overly bright top end but mainly saw weird asymmetrical clipping out of the front end to the point the amp would go into heavy distortion at anything past 2W RMS output. It did have a very high input sensitivity but this clipping before the output tube grid crippled it to flea watt status.
Given I planned for this to be just a starting point for this amp, I gave this some thought knowing I wanted to try using these 6SN7 tubes. I thought about trying a cap coupled twin triode two stage, but then wired up the frontend very similar to the mods I did to the Nobsound 6P1 amp: as a Cascode with a voltage divider feeding the upper grid. I also increase the DC offset on the heaters of the 6SN7 tubes from 35V to 50V. This mod fixed the asymmetrical clipping and now can be driven to 6W RMS. It lost some of the input sensitivity but most of that was wasted on a normal line input, as the amp went into heavy distortion so easily. It now sounds 100% better and I feel like with a few minor tweaks (I plan to try a 0.33uf coupling cap etc) will be a great amp.
Where I am baffled is I have seen several articles about builds based on this design, using some high end transformers etc., praising how great it sounds. I was also told some of the current production ChiFi 300B amps use this design. The problems I saw were easily visible on the grid of the 300B, so I don't see how $1500+ OT would fix those fatal flaws. I suppose if I had never heard a good tube amp and had very sensitive speakers I might have been impressed, but seriously my little 6BM8 amp sounds much better, more solid bass response and has almost as much drive! Rewired as a cascode, this 300B amp now sounds more like you would expect.
Anyway, if anyone ever plans to use that schematic, I would suggest they not bother, and instead try to this cascode front end design I came up with. I'm also interested in other designs using a pair of 6SN7's to drive a 300B.
