The Micro DD-8 is another very popular direct drive model that shared the high torque motor with your DDX-1000, but in a more conventional and elegant looking rosewood base.about BL-91: i have never heard one but i see that after RX-5000 it is the most sought after, but its not direct drive, is it? love direct drive tables. the MA505 also seems like just the bees knees as far as these vintage arms go.
Regarding motor lube, some disassembly is required, I've done mine before. It shares the same Matsushita motor as on the Kenwood KD-500, Micro Seiki was involved in the design of a lot of the Kenwood tables during that time period, and there is a good website dedicated to servicing the KD series. You can also refer to the KD-500 service manual for the motor and internal servo electronics since they are the same, the Micro DD-40 service manual doesn't cover the motor internals... https://liquidaudio.com.au/kenwood-kd-500550-turntable-motor-service/I recently picked up a nice DD-40 with a Grace 704 arm. Those two look good together in my opinion. Added a NOS AT13E to get things rolling. Does anyone know if there is any lubrication needed for the motor? Nothing I have read indicates that and I am not sure where I would add oil if needed.
I just use a good quality synthetic motor oil, in my case Mobil 1 5W-30.Thank you @The Slider. I have gotten down to the sensor and was not sure what to do next. I will give this a try. Any suggestion on which bearing oil to use?
