Had this player for a while. Started having issues playing discs. Opened it up and found the laser lens loose. Pulled the disc clamp arm to access the laser. Glued the lens back & and put the disc holder back on,.had issue getting it back in, finally did. Then had issues with drawer opening & closing. Played with it, pulled the drawer out. Worked on getting the clamp straight. Now it will open but not close when I push the button. I can slightly push on the drawer front & it will close. It will now play a disc fine, just the drawer is mucked. Suggestions?
