Hello everyone,
I recently purchased a Sansui 881 from the flea market. When I got it home, the first problem I noticed was that some of the front lights were out. Next, I tested the unit with speakers and did not find any noticeable problems. All channels seemed to be loud and clear. AM FM came in perfect and all other inputs worked. Since everything seemed to be working correctly, I decided to replace the front bulbs with LEDs.
The unit looked and sounded perfect for about two weeks and then I began having problems. First one of the LED lights started to appear dimmer than the rest. Then, the sound stopped working on all channels.
I took the unit apart again and cleaned all the connections, knobs and buttons. I noticed that 3 fuses were blown and replaced those next.
I tested the unit again and was able to get the unit to produce some sound using the AUX input. The sound only worked when I turned the volume almost all the way up. The sound is some what clear, but also has some static.
This is one of my first restorations and I’m not really sure where to go from here. I apologize if this may have been answered before, but if anyone has any advice it would be greatly appreciated.
