I have a Sony STR-V35 receiver that won't come out of protection. The weird thing is, both the bias and DC offsets test fine. I actually tried adjusting them, and I got the offset as near to zero as I could, and the bias set at 20mV, as per the service manual.
There is around 38v on both sides of the relay coil, and grounding the one side that goes to Q616 makes it click in. I should add that I did this after pulling and testing Q616. It almost seems like there is something wrong in the protection circuitry that is causing the problem. I did remove and test all the transistors in this circuit, they all tested fine. With Q414 removed, the protection relay clicks in.
Something else seems strange. See all those components with the red lines though them? They aren't installed on the board on my receiver. It doesn't look like anyone has been in there before and removed them. Maybe the Sony designers realized they didn't need them? The inputs marked 1-2-3 and 4-5-6 are taken from each emitter resistor and it's common ground.
I did measure a whole bunch of voltages, but I lost the paper so I'll have to do it all over again.
Lee.
Lee.
