oranda
A bit of a bombastic title, but after owning and building multiple different phono preamps, I’d like to share what just might be the best phono preamp available for under $1000. Known to many of us, the Hagerman Bugle 3 is a well-designed phono preamp that features a split-passive RIAA filter and is a fantastic value at around $200. For those handy with a soldering iron, Jim Hagerman also offers the circuit board of the previous version (the Bugle 2) along with a parts list, schematic, and build instructions for a mere $40. The stock Bugle amp sounds very good, is quiet, and easily makes the short list of “best buy” components in its price category. However, performing the simple parts substitutions outlined in this post will produce a preamp that exceeds expectation in almost every way.
What are the specific improvements over the stock Bugle? Immediate improvements in resolution, transparency, and detail. High frequencies will sound more natural and coherent, while the overall presentation have an openness associated with discrete-device preamps. Vocals will have better presence and sound more organic, and low frequency information will be more obvious.
In order of importance, the parts to upgrade are as follows (as identified by their label on the Bugle 2 schematic.) Having a decent DMM or LCR meter to help verify and match the left and right values of each component as they are added will help keep the channels balanced and the overall performance close to published values.
A quick thanks to Audio Asylum member amandarae for introducing me to Hagerman Audio Labs (whom I have no affiliation with) and johnc124 for posting about TI’s super-beta BJT line of op-amps on diyAudio. I would also like to give a huge thank you to fellow karma member @desertrat748 who not only tested and provided exceptional feedback on various Bugle iterations, but also built his own modded Bulge 2 and provided an excellent leopardwood case that will be shown in a future post. Many thanks!!
- Op-amps: the Bugle 2/3 recommends/comes with well-regarded LM4562 audio op-amps. However, after trying many different devices, I found that substituting TI’s excellent OPA2210 in the U2, U3, and U4 positions yields a level of performance that will make you question why op-amps were ever disregarded as high-end devices. While the ultra-low noise, super beta OPA2210 op-amps are only available in a surface-mount format, they can be installed after being mounted on SOIC-8 to 8-pin DIP adapters. I use Brown Dog adapters available on the Cimarron Technologies website. If ordered pre-mounted and with pins installed, they drop directly into the 8-pin sockets on the Bugle circuit board. A chip puller is highly recommended when removing op-amps.
- Film capacitors:
- C5 capacitor: Replace the 10nF capacitor in the C5 slot with a silver mica capacitor of the same value. I am presently using 10nF CDE silver mica caps which mount easily due to their having a very similar lead spacing as the original Bugle2's C5 capacitor. However, any good quality silver mica will likely due (Charcroft caps would likely be excellent.)
- C4 and C6 film capacitors: There are several great options for the 220nF capacitors. Two easy recommendations are ones I am using: the Amtrans AMCG series and the economical Vishay MKT1822 capacitors. These both have a mellow yet detailed presentation, with the Amtrans being more nuanced and a direct fit into the C4 and C6 slots. I have also used Auricaps XO polypropylene film capacitors in the C6 position (the XO is a difficult fit in C4) as well as Kemet SMR-series polyphenylene sulfide film capacitors (in both C4 and C6) to good effect. All the listed options will be a noticeable sonic upgrade over the recommended Kemet PHE426 polypropylene capacitors.
- Power supply: I am presently using a 24VDC 0.5A linear and regulated power supply (Jameco Part no. 174879) in place of the switch mode supply.
- The Xicon 271-series 1/4W resistors specified in JH’s parts list are perfectly fine, but I really like the (not-so-expensive) Takman REY 1% metal film resistors and now use them whenever a resistor of the recommended value is available. I’ve found the most important resistors to upgrade (and keep closely matched) are the cartridge loading resistors R2L and R2R, but feedback resistors R4, R9, and R13 (both L and R) should also be considered. For values where the Takman REY resistors are not available, I also like Vishay/Dale CMF ≤1% metal film resistors.
- I’ve recently experimented with using TI’s OPA1612 opamp (also available on the Cimmaron Technologies website) in the U4 position. This is the configuration I like for my vintage Empire and high-output Audio-Technica cartridges as it produces amazing bass with neutral mids. However, for my MC cartridges, I prefer the coherence and black background attained when using three OPA2210 op-amps. Using three OPA1612s did not sound as good to my ear as the other configurations described here, but YMMV.
