Milano
Member
I've attached the supposed specs of my Denon AVR-1610 and my HK 3375.
I have some of my own opinions already but never mind what I'm thinking, what would you guys pick if you had both of these sitting in your house, to run a turntable and a tuner?
The HK definitely sounds warmer to me and I like it. I also like the functionality of having a bass and treble knob plus the two outlets in the back to power my turntable and a set of small fans that I usually keep on top of my receivers to aid with cooling. I'm told it should handle a 4 ohm load if I wanted to since it can simultaneously handle two eight ohm loads on two different zones. I read something about a high current 42 amp power source in this.
The denon, because it can output five channels times 75 Watts at 8 ohm, makes me think it's got better power. I'm not sure if there's any truth to this. It also sounds pretty good with the art DJ PRE. I haven't set up Audyssey or any of the dynamic EQ functions because I don't have the remote... And I'm wondering if that would give it the edge eventually... Although I'm not sure I can do that because the HDMI circuitry was damaged in a power surge. I can't use it to output any video, only for audio.
I don't have the remote control for either right now, which also makes the Harman kardon easier to use.
I'm running jbl a-130s which are 6 ohm.
I know much of this is subjective and the specification seem to make them very close to one another. That's why I'm not interested in what would be best to me today. I'm curious what you guys would pick and why? Maybe you know something about the build quality or the chipsets or other things that I'm not aware of.
