I forget in which forums, but I recall reading of the disappointment of people who replaced the electrolytic capacitors with film capacitors. The sound was not as good after the switch. The manufacturer of the originals is still in business. I emailed a retailer in England (Falcon? I can’t remember - it was 2015) who said he regularly ships them to people in the US.
My pair of SL6 have two film caps and two NPE caps.
I also have a single SL6Si and it has a much simpler crossover with all film caps.
Simpler because the aluminum tweeter does not require a notch filter or the series
inductor to tilt down the top end - perhaps also because they wanted a bit more top end.
Edit: The aluminum tweeter is the same in all of the SL models, as far as I know, the SL700
is measured here in the Stereophile review where a 10 dB dip can be seen at about 15 KHz,
and a 10 dB peak at about 23 KHz. The dip starts falling fast above 10 KHz which is strongly
audible even to old people. See Figure 1: I'm not impressed with this "improved" tweeter:
https://www.stereophile.com/content/celestion-sl700-loudspeaker-1991-measurements
I have 3 of the aluminum tweeters and will try to measure them, JA's measurement looks
like a defective tweeter.
I found an SL6S crossover for sale on ebay that looks nearly identical to my SL6Si
except for the S having all NPE caps in contrast to all films for the Si. The tweeter
pad resistor is the same at 3.3R 10W, the tweeter cap values are the same at 4 and
6 uF. I can't read the woofer crossover value on the S so not sure on that one. The
Si board has a slightly different layout, I assume to handle the larger film caps. Both
have tweeter inductors that look the same with very fine wire.
I've heard that the S sounds better than the Si and so far they don't seem to be very
different and I'm not sure if the claim is just a myth.
Edit: A friend outboarded his SL6S crossovers and loaned one to me for measurement.
Woofer inductor (has a different part number) is 2.8 mH, and on my SL6Si the woofer
inductor is 2.6 mH. Everything else is the same. Tweeter inductor is .25 mH.
I'm going to start a new thread on the differences where I'll show pictures of the crossovers,
and schematics if I have time.
