Old Vinyl
I have a nearly 50 year old Thorens TD 126 mkII fitted with a Fidelity Research FR64s tonearm that has recently blew a fuse. It has the original electronics and I realize this probably means replacing capacitors and related parts to bring it back to life. It's a nice sounding turntable recently restored with custom plinth, new dustcover, Linn black springs, etc. Although I'm dazed and confused, my possible options are:
1. Replace motor and electronics with Origin Live DC100 motor kit. This seems like the easiest solution and should prevent any future electrical failures. I'm a little concerned about the mounting options available with the kit but should be able to figure something out. Has anyone successfully installed this kit on their Thorens?
2. Purchase a capacitor kit from seller on Ebay and carefully try to replace the suspect electronics. I've done this kind of thing in the past but now at 70 years old, I am concerned how stressful the job may become. If I go this route a schematic showing the capacitors that should be replaced will have to be located.
3. Send the circuit boards out to a reputable shop and have them replace the faulty electronics. This would also be fairly easy for me but when completed I still have a turntable with 50 year old circuit boards which could be problematic in the future.
If anyone has suggestions it would be appreciated. I have three other turntables that I can use including another TD 126 mkII but the FR64s tonearm is special and sounds magnificent with a Denon Dl 103s.
Thanks in advance for your help!
