noveltone
Hello guys and gals,
It's nice to be starting a thread for the first time in a while! Recently EW said that as a matter of course he replaces the relay driver transistors on amps' Protection boards. Like a little sheep I would like to do the same to my beloved AU-919 since I'm going to go in there and try out Nicowico's fast output transistors, among other things. :zoom:
Its always blinked forever when I turn it on, so maybe this will help that issue. Anyway, I'm pretty much out of my league in determining which of the transistors on that board are the relay drivers, but here are my guesses: TR601, maybe TR604, and TR607. I've attached that portion of the schematic for your delight.
Now, since these are not even audio-application transistors, I am way out of my league in which stats are important to try to match and which aren't. :scratch2: Would one of you kind, knowledgeable folks take a look at these and see if can recommend a commonly available modern replacement? Thank you very much!
TR601: 2SD357
Original:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-9/DSA-167009.pdf
Suggested Replacement somewhere here on AK, maybe CDfixer: 2N4920
http://www.onsemi.com/pub_link/Collateral/2N4918-D.PDF
TR604: 2SD438
One thread suggests 2sc2235, but that isn't available at Digikey. Any other ideas?
Original Datasheet:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-8/DSA-158376.html
TR607: 2SC945
This one is pretty much covered by this thread: http://www.audiokarma.org/forums/showthread.php?t=129112&highlight=c945
Therefore I'll use the available 2N3904 for this application.
Thanks again!
Collin
TR601: 2SD357
Original:
TR604: 2SD438
Original Datasheet:
TR607: 2SC945
Thanks again!
Collin
