bowtieman427
I know this was started in an older thread but I started the restoration last night and ran into some major problems. This is an early version and was wroking fine. I am using the metalbone kit and completed the first part.
-Per my pics what is the yellow jumper wire for by the big yellow orange bias cap ? It connects to a black wire second pin in from left to right and to a side of an AC convience outlet. With the jumper removed the unit will not turn it on.
see pics here on page 2-3 the interenals are posted.
http://www.audiokarma.org/forums/showthread.php?t=133427
Now I replaced the bias circuit new caps and bridge. 123V L-N input. Prior to replacement I had -14V on V13,14,15,16 pin #2. After replacement, V13,14,15 had -16.75V and V16 -15.75V on pin #2. -27.5V out of new bridge. 423V on + side of 100uF cap C 76 and 208V on - side. Few miutes into test tube V14 blew many colors I unplugged ASAP and tried to remove but the bottom glass is broke all the way around. Needless to say this was an original Fisher tube looked on internet and original are very hard to come by and cost $$$$$$
Unit was upside down with 8ohm load attatched to outputs.
-What went wrong ? Any ideas ?
-Can I remove all tubes and test without them in and without hurting other things ?
-How do I test my output tranformers and see if they are ok ?
-My new plan is to complete the restoration with no tubes in and then put in aftermarket tubes in any ideas on what to get ? and what do I test/check prior to tube install so I do not destroy them ?
I was doing this restoration to save on parts namely tubes so far not good.:tears:
thanks in advance
Jim
thanks in advance
Jim
