Detailman
Addicted to tweaking
Here I am again.
I've been working on this burned up 950 amp board for some time.
Finally got all together after a couple different parts orders.
First time I put it back together last week it got real hot when testing and setting bias. vr 1-2-3-4-.
Found out vr-3 was toast. Refer to this post for q's
http://www.audiokarma.org/forums/showthread.php?t=132968
I've replaced vr3 + 4 and meant to replace vr1+2 but ordered wrong for those. DOH
Anyway powered up and did adjustments on amp board per S/M.
Going fine. It's been running for 30min. or so and showing no signs of heating up. So far so good.
Couple questions.
Should I hear the relay click without the jumpers in?
I don't think so but I'm thinking my next step is to insert jumpers and then listen for relay and check dc offset.
At this point after a couple weeks work I don't want to make the wrong move now.
All transistors and caps on the amp board have been replaced along with a couple of other burned up parts.
All other boards except the tuner board have been recapped.
No smoke, no smells so far.
Just looking for guidance.
Thanks again.
Couple questions.
Thanks again.
