Sluggo
I recently aquired a pair of Polk Audio SDA-1A's
And they specify the power source must be
Common ground!The speakers use a inter-connect
cable to join them,Which I do not have attached,yet!
Talks with Tentoze(thanks much)It shouldnt matter
about the common ground until thier interconnected.
I have the goods to make a cable & paused to ask!
I know mainly polk is speaking of not to hook up Mono
Block amps or not to bridge amps to them,
I want to hook them up to my Carver M-1.5T Amp
and C-1 preamp and just want to make sure of this,
before procedding.I dont have the O.M. but a spec sheet that does not specify it:scratch2:
Sluggo
Sluggo
I just checked my old dusty spare M1.0t, and it clearly shows the right channel output as being grounded. So if you connect a speaker between the Right channel's "hot" output and the left channels ground, you will get no sound at any position of the balance control. And if you connect between the left channel's ground, and the right channels hot, you should get sound at all positions of the balance control, but the minimum should occur at the center position.
