dc270
Now Off the Reservation
This is going to be a twist on one of my favorite Advent speakers. It is basically a Smaller Advent on steroids, or done to the “quads” in a classic line array. The cabinet is radical departure from the original ones however. It has a raked minimal baffle plane set up for the woofers and a unique tweeter “rail” system. The rail allows each individual tweeter to be adjusted up or down and in or out on the 2, 3/8" threaded rails and tweeter frame eyebolts. This setup should eliminate baffle board diffraction issues and sympathetic woofer vibrations for a cleaner detail sound.
I choose the Smaller Advents because of their great bass capability, pretty good midrange and good tweeter offering. To maintain the original “flavor” of the Smaller Advents I went with the same tweeters, repainted the frames and added a soft cork piece to the tweeter face to help with any more diffraction issues. The tweeter rails will be mounted to the side of the woofer cabinets with rubber grommets to eliminate vibration transfer. All the woofers have been re-foamed and the cones treated to help smooth out the midrange.
The one caveat to this design will be the obvious size- but the predicted output should be well worth it though. It will be wired in series parallel and should have very good power handling and excellent imaging! It will still be their classic acoustic suspension design with "polyfill" used inside the cabinets. This should still be a 4 ohm system & will include an L pad for tweeter adjustment. I have not decided on a cabinet color or cover scheme, but will it probably be black. Fixed wheels will be attatched to the back for easy manuvering.
The pictures are the early construction phase of the cabinets and the tweeter rail mechanism. I built this same "tweeter rail" 25 years ago using a differant set of tweeters and had pretty good success with it then.
I will post more latter as it developes. Thanks for looking-
DC
DC
