matel said:
What does 'clipping' sound like ?
And while we're at it what is clipping technicaly?
Sound like? Odd order harmonics.
Technicaly speaking? When an amplifier is pushed to create a signal with more power than it can support, it will amplify the signal only up to its maximum capacity, at which point the signal will be amplified no further. As the signal simply "cuts" or "clips" at the maximum capacity of the amplifier, the signal is said to be "clipping." The extra signal which is beyond the capability of the amplifier is simply cut off, resulting in a distorted waveform.
Many electric guitar players intentionally overdrive their guitar amplifiers to cause clipping in order to get a desired sound.
All amplifiers have a maximum amount of power, so theoretically they all can clip. However, many amplifiers will not allow a user to turn gain up beyond that point, so that the amplifier never clips. This is sometimes to reduce accidental distortion, or more importantly, to keep from damaging the amplifier as some amplifiers cannot withstand the heat generated by some forms of clipping.
In power amplifiers, the signal from an amplifier operating in clipping has two characteristics that could damage a connected loudspeaker:
Because the clipped waveform has more area underneath it than the smaller unclipped waveform, the amplifier produces more power when it is clipping. This extra power can damage any part of the loudspeaker, including the woofer or the tweeter, by causing overexcursion, or by overheating the voice coil.
In the frequency domain, clipping produces strong harmonics in the high frequency range. The extra high frequency weighting of the signal could make tweeter damage more likely than if the signal was not clipped. However most loudspeakers are designed to handle signals like cymbal crashes that have even more high frequency weighting than amplifier clipping produces, so damage attributable to this characteristic is rare.
There, I must sound like an expert. Actually, I copied that from Wikipedia.
