wrcraw1965
I just bought a Pro-Ject Debut III in Glossy Piano Black, and set it up.
Well, I wish I would not have bought it, and it is going back for a refund.
I will tell you why!
Beware buyers of buying a turntable with a steel, or iron platter!
I have seen a thread or two on AK about some low level hum noise in between tracks. Well, that is the first thing I figured out with this "turntable".
It does not do it, until the supplied Ortofon OM5E gets near the platter!
In addition to the low hum, there was considerable ripple noise present if you cranked up the receiver.
Then, I proceded to install a new Denon DL-160 cartridge. I sat back with my remote, and prepared for a fine listening experience. After installing this cartridge, I did not notice the low level hum, or the ripple noise in the amp, and I set the needle at the begging of track 1, and kicked back.
The sound from the DL-106 was definately improved over the OM5E factory supplied, and it should be.
Well, everything was going well for about 40 seconds! Then all the sudden the needle took a ride accross my vinyl! I was like, what the He..!
I grabed a falshlight to look closely at what was going on. The cartridge body was flat down on the record! I first thought that the cantilever suspensoin had given up the goat! Turns out, the DL-106 has such strong maganets in it that the steel platter sucks the cartridge flat to the surface of your treasured LP, even with two more junk LPs stacked below it as a spacing experiment!
Needless to say, I'm POed, big time! Then I read in the Denon manual that it can not be used with a steel platter! "All else fails, read the instruction manual"!
Well, at least Denon is a reputable enought company to tell their customers about such things, and also to manufacture a quality poduct with such strong maganets, etc. That is more than I can say for Pro-Ject, and their el-cheapo steel platter strategy!
Entry level "Audiophile"? Yea, OK! "Audiophile" my arse!
Well, the cheapo junk is going back, and I've already ordered a new Denon DP-300F off of Ebay for $250, which is $80 less than this other piece of junk!
The Denon has better specs, and is fully automatic, cosmetically superior to the Debut, has a removeable headshell, which was a pain in the arse on the Debut trying to change cartridges, and MOST IMPORTANTLY, has an Aluminum platter!
Folks, non-magnetic platters are our friends, when it comes to turntables. Who in the heck at Pro-Ject ever decided to put a steel platter on? Duh...!
Sorry Pro-Ject, you're too stupid to earn my hard earned cash. I guess, you will continue to sell this crap TT to more unbeknownst victims, rather than putting a decent platter on your product. I guess, since it is supposed to be "Audiophile" grade, a decent platter would cost me at least another $200, right? Well, too bad, I'm buying the Denon for less, and it will be a better TT!
Signed,
Some Sucker Born in PA
(Not for long, Pro-Ject!)
Signed,
), but it will be helpful information to those who are entering the vinyl arena for the first time.
