Yes, need good parts box for the spring, sharp xacto for washer and a few SMALL hand tools, once the thing is actually out of the deck. That transport assembly is held in by 4 big screws and usually glued during assembly as well.
There are cables and connectors involved, as well as a little manuvering to clear the tape counter which sticks out on the left.
The gallon plastic bag trick is ESSENTIAL as those parts really want to fly....
they are under considerable tension. especially after that little plastic part stops holding the clutch tension.
I had some other pictures, but they are confusing even to me, (even though I TOOK them!!) as the 3 dimensional aspect us usually lost in a photograph, and that is why I have never posted them, would just confuse and dishearten people.
In your place I would get the belts
(they should be same as 9191 but check the pioneer site, it will take some digging that I won't have time for tonight, have a 6pm appointment.)
and clean and de-oxit the unit and see if it can be coaxed to play and record.. remember, you can "back up" a tape by flipping it and playing it the other way, it's a pain in the a$$, but if the deck dosen't rec/pb well, then why spend time on ff/rew.
Good luck, back tomorrow....
