<moved from wrong forum>
Having a problem with the integrated speaker select/power switch on this LR5555. In both A and B positions, i need to 'lift' up on the knob slightly to get power until the tell-tale click of the amp. Otherwise, no power. A+B, A+C and C are dead. The only reliable connection without a 'lift' or wiggle on the knob is the headphone setting.
Ive done the typical: compressed air, electronics cleaner, de-oxit, check solder points carefully for any weak joints. Short of pulling the switch and replacing, anyone have suggestions what might be the problem ? bad connection, loose wire, worn switch ?
Further, if I need to replace, finding a parts-only lafayette or a switch from one is bound to be a problem. Can I cross match with a switch to another brand ? Several kenwood's nearby ($15-20), I think they have similar selector types if I am not mistaken. Its identical internally to a Setton RS440 I've read, if that helps identify.
I swear this thing is my nemesis, but I love it.....Its an a amazing unit and performs better than the stated 55w per channel. I did check with a local vintage repair guy, he doesnt think its value is worth repair (huh ?)....guess if its not Sansui, marantz and the like, it isnt worth repair to him...to each their own I guess.
Pics are attached if anyone has ideas for troubleshooting or what might match for the switch.
Thanks in advance.
Thanks in advance.
