mhardy6647
Lunatic Member
I thought it might be helpful to someone out there to document an interesting and fairly well-known "feature" of some of the Magnavox tube stereo power amps that some of us are fond of finding/collecting/rehab'bing. If everyone knew about this already, I apologize for the redundancy.
These amps are generally on separate chassis than the tuner/preamp sections in the consoles that contain them, but are somewhat tightly integrated to the preamp by an umbilicus and a multi-pin Molex connector. AK member Cabinover had gotten such an amp which had been modified for standalone use, but he noted that the gain in the amp was very low. He asked me to take a look at it.
Fortunately, there is a good "Magnavoxfriends" group on Yahoo, and a few Magnavox experts kicking around (e.g., Gabe V., who has a site of his own, as well). This particular amp seems to be the "88-01-00" chassis. It turns out that some of these stereo amps use the (preamp's) balance pot as part of the feedback loop from the outputs. Bypassing the umbilicus open circuits both channel's feedback loops. It further turns out that all one needs to do to "fix" the problem and restore the amp's gain is to replace the balance control with a pair of 390 ohm resistors (one for each channel) tied to ground.
I tried to take advantage of the bright AM sunshine today, but only succeeded in demonstrating yet again my lack of photography skills!
Here's das Ding an sich:
Here are the underpinnings in toto. Note the replaced coupling caps from the paraphase splitters to the PP 6V6 outputs:
Here is a close up of the 390-ohm carbon film 1/4 watt resistors added to "replace" the balance pot and close the two channels' feedback loops.
Reference: http://db.audioasylum.com/cgi/m.mpl?forum=tubediy&n=112480
These are nice little 10-watt stereo amplifiers and if found cheap or free well worth simple restoration or complete rebuilding/modification, depending on one's level of motivation. I hope this is helpful to someone.
