Finally, an upgrade.
When I got out of college I picked up a Nikko Alpha 220, Beta 20 preamp and a Gamma 20 tuner. Well, through a local AKer I finally scored a nice Alpha 230, Beta 30 and Gamma 30 for the collection.
I did a few upgrades to the 230:
5-way binding posts
Recap the amplifier stages with Nichicon FG and Muse caps (didn't do the protection, display or regulator circuits)
Replaced the 2 - 1uf bipolar input capacitors tied to the Direct/Normal switch at the RCA jacks with a pair of Nichicon Muse caps. Also repalced the 1k carbon film resistors with 1% metal film parts
Upgrade the opamp from a 6552 to an OPA2134 (fet - and installed a socket)
Replaced the bulb for the meter scale
Cleaned the switches and PCB crud
Adjusted the idle current to 18mv
The opamp amp upgrade is probably not entirely necessary since the opamp is used in the servo circuit that automatically adjust the bias to the power transistors.
The bulb replacemnt was slightly tricky as I didn't have a large 6 volt bulb with wire leads like the original.
I replaced it with a 6.3 volt bulb with a bayonette base and I soldered the wires to it then put heat shrink over it and held it in place with a little silicon sealent.
5-way binding posts
