JohnMichael
My Rega Planar 2 was purchased in 1998 and still using the original motor. Rega announced an update a few years ago but I did not feel the need to change. The latest motor will allow me to upgrade to the Rega TT PSU in the future. I like the idea of better speed control and speed change electronically without the need to change the belt on the pulley.
My Planar 2 is modded with the Incognito rewire, Michell Technoweight, DeepGroove subplatter, ceramic bearing, Funk Firm Achroplat platter and some RDC cones. The subplatter was a big improvement in speed and why I did not feel the need to have the rigid mount motor. Now that the new motor is supposed to be even lower in vibrations and I could use either the walwart power supply or the Rega TT PSU. The new motor does away with the AC cord and the housing has the two inputs for either the walwart or the TT PSU but as they warn never both.
I have my supplies purchased for this mod and will be replacing the motors on Monday after UPS delivers. I will be listening to two records before and the same two afterwards. I am not sure if I will be able to say how much improvement just using the walwart alone. Regardless I have a brand new motor for another 14 years. I do plan on changing the main bearing lubricant while I am at it.
Will let you know what I hear.
