How much is from cartridge, how much from stylus?
Paul C
How much of the quality of a cartridge is due to the cartridge itself, and how much is contributed by the stylus?
I have always purchased medium good cartridges, as much as I could afford at the time. I have a nice cartridge in my Technics turntable now, a Radio Shack (Shure) RXT6, which is a P-Mount, same as Shure's M111E. I have two new N111E stylii and it is playing perfectly well now with a N97xE stylus.
I just purchased another turntable, an Onkyo CP-1400a. I bought this mostly with the intention of occasionally installing a 78 cartridge and archiving 78's to my computer (converting from 45 to 78 in the computer).
The cartridge that came with it is some unidentifiable junk. I have a M92E ordered which should be here tomorrow.
I know this cartridge will accept better stylii, such as the N111E's I have for my RXT6.
If I change to one of the better stylii I should get better performance, but how much better to expect? What contribution is more important, the stylus or the cart body? 50%-50%? Or is one or the other more important?
Comments?
Interesting question to ponder....
I think I would venture to say the stylus is more important...maybe 60/40. Like you, I have swapped out styli on cartridges (the v-15 type iii, for example) and noticed a significant improvement or degradation of sound. Those original "hyper-elliptical" or "super tracker" styli are fantastic at extracting every bit of info from the grooves. On the other hand, I have yet to find a non-Shure stylus for the Type III that I like as much. They are good, but not up to the status of the original.
Now you can't take a Benz Micro Ace stylus (if it would fit) and slap it into a Shure m97xe and expect greatness either. I do believe the technology that goes into making the more expensive cartridges does contribute significantly, but just not as much...thus the 60/40 split. Put a lowly conical stylus on the Benz, and I bet your tracking and extrication of musical info would be suffer dearly.
So that is my 2 cents...60/40 Stylus/Body.
Dave
I don't have a lot of comparative experience with this, but my intuition and the impression i've gotten from cart manufacturers is that the cart can be much more important. The stylus certainly contriubutes plenty to the price (the ortofon super series is a very good example of this; its a range of carts all with the same body but with swappable, progressively better styli), and is definitely important, but it seems to me that the inner workings (and body material) are the key elements.
I note that most of the cost of a cartridge is in the stylus. I wondered what could they really do in the cartidge body that would make much difference in sound. It is easy to see that stylii can be quite different, shapes of tips, etc.
It will be easy for me to swap these P-mount cartridges I have... both are Shure, both will accept the other stylus. I can easily try both on the same turntable.
I'll have to set up some testing and see what happens.
Results of tests:
I tried the M92E vs RXT6 (M111E). Both are P-mount, so that made swapping fast and easy. Both will accept the same stylii.
I had earlier determined that my RXT6 sounded the same with both the N111E (original type stylus for this cartridge, now out of production) and the newer N97xE (in current production). Since they both sounded the same, I did not include the N111E in this test, only the N97xE.
I tried the RXT6 cartridge with both the N92E and N97xE stylii. For a test record I used the opening passage of Mars, Bringer of War from the Holst Planets. This recording has a very wide dynamic range, percussion, strings, brass.
The RXT6 was already set to 1.25 grams tracking force, and I have been happy with that. Actually, 1.75 grams, with the "dynamic stabilizer" (brush) relieving 1/2 gram, for an effective 1.25 grams on the stylus. The Shure spec sheet listed this stylus tracking force as .75 - 1.5 grams (1.25 - 2.0 with brush).
With the RXT6 using the N97xE was very detailed, it just sounded right. I could hear chair scrapes and instruments rattling on very soft passages. I could clearly locate solo instruments (as opposed to string section).
Pulling the N97xE and inserting the N92E and setting to 1.25 grams (N92E lacks the brush), listening to the same passages, the chair scrapes and rattles were less distinct, it was not immediately apparent what those little noises were. Everything sounded slightly smeared, not quite the detail, though the highs were still there. It was as if you were reading and the room was darkened, the print not quite as distinct. Location of solo instruments not as good, and on the louder passages, again, a little hazy, indistinct.
Then I changed cartridges, putting in the M92E. First the N97xE stylus. I had to rezero the tracking force, there is an extra plastic part on top of the RXT6 which the M92E lacks*, so, this was a change of about 1/4 gram. Then I reset to 1.75 grams total (1.25 gram on the stylus) tracking force as I did for the RXT6. I really could not tell the difference between the M92E cartridge and the RXT6 when both used the N97xE stylus. All the detail and clarity were there with both cartridges.
*Other than the added plastic piece on top of the RXT6, the actual body of both cartridges appears to be identical. What differences there are internally one can only guess.
Replacing the M92E's original stylus, the N92E, the sound was once again smeared, lacked detail. It did not track well on the loudest passages, there was a warbling sound. To correct this I had to increase tracking force slighty to 1.5 grams, the maximum recommended for this cartridge/stylus, though 1.25 grams was listed as optimum.
My conclusion is that most of the "quality" is in the stylus, not the cartridge. If I had to put a percentage on it, I would say 80% stylus to 20% cartridge. And prices of whole cartridge vs stylus only reflect this.
I have no hesitation now about using the M92E cartridge. I will keep the N92E stylus for casual listening to pop, rock, etc, or as a "back up". But I will use the N111E and N97xE stylii for serious listening, classical, jazz, and copying records to eventually burn to CD.
After this experience I would not hesitate to recommend to someone wanting a better cartridge for P-mount to purchase an M92E and use one of the better stylii, N97xE, N97ED, N97EJ, N111E, or their aftermarket replacements.
My feeling is that the cartridge affects linear things like frequency response, and also can affect tracking, but the stylus affects mainly non-linear stuff like tracking - a poorer cartridge with enough tracking force can be compensated by equalization, but a poorer stylus can easily degrade performance in ways that cannot be compensated.
My ears quit about 13-14 khz, nothing above 14khz. Even if there is a little difference at 18k, I am not hearing it. And from sound lab work I did when I was much younger there is not much to be missed up there.
