Thanks for the help guys!
Oh, that amp has the rectifiers and filters built in. It's meant to be used with a transformer. Did you check the seller's other items? He's likely to be selling the matching xformer for this amp. With that PS requirement, it must be putting out 100W or more...
Yes, I tried that and also sent a question with no luck yet. Looks like the moderator did remove the ebay link (whoops sorry!).
Do a search on TA2022 and it should pop up?
Here are some of the specs:
Basic features:
1. Midpoint voltage precision adjustment and DC shifts protection.
2. With over-voltage, over-temperature, over-current protection indicator
3. Ultra-thin design perfectly compatible within 43-44MM aluminum cases
4. One board, OCL BTL two options for eash choose. When connect it to BTL way, it can output 200W power, easily drive big speaker.
5. The amplifier integrated power and protection circuit. With more reasonable components layout and more superior performance, convenient installation, will give you a whole fresh enjoy.
Using double-sided PCB design. Adopts special "analog and digital" clothing panels. Close the chip switch power supply inside and using external regulated power to provide more cleaner power to ICs and circuits. The noise control is very good, no matter big volume or small, no any hum at all.
Components list:
1. TA2022 chip, Tripath original analog input class T digital power amplifier.
2. 3 terminal voltage IC: Japan, NJRC original NJM317F, performance is better than NJM7805A MOT, ST.
3. First power filter use top class filtering capacitor: adopt Japanese original NCC four 4700UF50V and one 4700UF16V, guarantee the surging power support.
4. Secondary filter: Taiwan Suncap power, 2 1000UF50V, LOW resistance, LOW frequency switching circuit ESR optimal collocation.
5. Precision adjustable potentiometer: original American BOURNS, 10 laps precision, stable and reliable performance.
6. CBB capacitance: all original RIFA EVOX Sweden.
7. Particularly customized 10A import red ring output inductance, any temperature and large current can ensure stable performance.
8. Original new omron relays, Germany ERO axial pin (MKT metallized polyester terephthalic acid ethyl ester) two special audio fever supplements capacitor
