Having been infected with the Vfet bug some time ago, starting with refurbishing a Sony TA-5650 (with much advice from Echowars), I've been on the lookout for a TA-N7B. I finally purchased one a few weeks ago and it arrived today. Thankfully it was well packed and arrived safely
. Except for a few minor cosmetic defects she is clean and appears unmolested. It looks to be an early model having serial #500064.
Upon arrival I observed that it is a 220v model with an IEC plug adapter. The U.S. seller ommited this information in his ad :thumbsdn:. I don't see this as a major hurdle, but I would appreciate suggestions on the best way to deliver power to it since I'm in the USA where 120v is the norm. Off the top of my head it seems I have a few options:
1. Use the schematic to wire it as shown for the USA/canadian model (I have the manual)
2. Buy a step-up transfomer (what brand/type would you recommend?)
3. Run a 220v line to where I want to use the amp. I am planning on some electical upgrades to my home soon anyway (new main service panel, extra outlets...)
Also, can I just connect a 220v electric dryer cord/plug to an IEC termination at the other end and plug the amp in to my 220v dryer outlet for testing? BTW, it does show 50/60 Hz on the back (photo).
Other things of concern are:
1. The fusible resistors which other members have mentioned are prone to drift in value on this amp. I want to replace these. Any recommendation as to brand/type?
2. I see in the schematic they show some double diodes. Are these like the ones in earlier Sony Vfet models that are prone to failure? I did not look yet to see if they appear to be the same.
3. I plan on recapping the amp with panasonic FM and/or FC capacitors. Are there any good replacements for the main filter caps out there that one of you has used? I don't know if I'll replace those yet, but would like to know if any of you has experience with a good substitute
4. I see the Vfet devices use an insulator that is soft like a modern Bergquist Kapton instead of Mica and grease. Should I leave these as is or would it be beneficial to switch to the Kapton?
I look forward to hearing from any other Vfet enthusiasts and will be happy to post photos as I progress. Please see an initial arrival set of pics below!
. Except for a few minor cosmetic defects she is clean and appears unmolested. It looks to be an early model having serial #500064. Upon arrival I observed that it is a 220v model with an IEC plug adapter. The U.S. seller ommited this information in his ad :thumbsdn:. I don't see this as a major hurdle, but I would appreciate suggestions on the best way to deliver power to it since I'm in the USA where 120v is the norm. Off the top of my head it seems I have a few options:
. As always, any help is appreciated.
