TAPEPATH
I have a classic AR XA turntable that has been overhauled by AK member marcmorin and have enjoyed it thoroughly. I'm working on another table of mine and thought I'd do some wow and flutter measurements. Since the AR was at hand I connected the meter up and made some measurements. The original specification, for the AR, was for the combined wow and flutter to be less than 0.1% using the NAB parameters. For reasons of ease of reading the meter I chose the JIS setting. For combined weighted w/f I measured 0.07%, with wow at 0.08% and flutter at .055%. The combined w/f, unweighted, was 0.09%. The measured frequency should be 3,000Hz, and the tested frequency was 3,0006Hz. If you read AR's original speed accuracy description they mention the ability to use a Dustbug and have correct speed. I don't have a Dustbug to test that.
Since I had a VPI Turntable power line conditioner at hand I repeated the test but with the AR connected to the VPI for AC. All of the measurements seemed to be very slightly higher with weighted w/f at 0.08%, wow component at 0.09%, flutter at 0.06% and combined unweighted at 0.09%. This was consistent at any setting of the rear panel adjustment or measurement scale. Granted it was extremely small, but still measurable. One nice thing was that I could adjust the playing frequency for exactly 3,000Hz. But my sense was that the AR kept better speed with good old house AC.
