I picked up a SX-3900 a while ago for peanuts knowing it had tons of problems with the amp board and power supply. I rebuilt the power supply with all new caps and transistors (luckily the 2sk34's were good) and all voltages are within spec. Then I started working on the amp board. I replaced all the transistors and diodes on there, and I had to replace the output transistors with MJL3281/MJL1302 and I made nice thick hold down bars. I used recommendations from the latest MTF list. My board is the later revision type which is the same used in the D7000, so I had extra diodes D135 and D136 which are 4.7V Zener, which I replaced with 1N5230B from Mouser. So I was extra careful and left the output transistors disconnected and fired up on DBT and got my 2nd relay click. I measured the voltages at the connectors and got numbers comparable to the SolutionRoom thread so I connected the outputs and fired up on 150W DBT. It dimmed down ok (117V at receiver) and 2nd relay click again. Measured DC offset and it was high but I was able to adjust using VR1 and VR2 to within a few mv of zero and it stayed there rock solid. So I moved on to the idle current. With pots to minimum I removed the DBT and put it on mains.
Now heres where the problem starts. I have idle current at the test points but the pots (VR3-6) are already at the minimum resistance. The left channel started around 45mv when I first turned it on and slowly increased to 78mv where it stopped. The right channel started around 63mv and slowly increased to 90mv where it stopped after about 15 minutes. I left it running for 2 hours and it didnt go any higher. It is rock solid, doesnt fluctuate around or anything. The heatsink is warm but it doesnt seem any warmer than others of this design type. I nudged the pots a little and it does go up but I cannot get it any lower. Is this a function of the on-semi outputs or should I be able to set it at 56/70mv?
