canuckaudiog
On a quest for high fidelity
Well, it finally happened to me. My T33 in my right Kef 104/2 started to distort, almost sounding like it was blown.
Now, it's well known that these tweeters use ferro fluid in the magnet gap to increase power handling and to reduce heat to the voice coil. I have no idea if this makes it actually sound better. Anyway, so I'm playing Bioshock and the right tweeter is most definitely distorting. Ah crap I think to myself, did the ferro fluid harden and ruin the tweeter?
Off with your head, Kef 104/2! Or more specifically, the front midrange/tweeter enclosure. I unscrew the 4 allen screws, pop it off, unwire it from the little PCB going to the internal crossover, and off it comes. Then it's just as simple as unscrewing the long screw that holds the tweeter in place, and that slides out of the way and the tweeter comes out.
Whew. That was refreshingly easy. All right, now I have to get the coil out of the magnet. Hmm.. well, let's test the tweeter as it stands right now. I get 10ohms.. that's not a good sign. OK, let's just get the coil out of the magnet and test it that way. The way it's held on is with a little piece of paper between the plastic baffle with the dome and the magnet. I had to pry this off very gently starting with one of the corners where the coil wire lead wires into. I say very gently because being plastic, putting too much pressure on one side could very well lead to it breaking. No thanks! With a little prying and time, the baffle comes off. I break out the meter and am now getting 5.8ohms! Ah, that sounds more realistic for a 6ohm tweeter. Nothing looks amiss on the actual coil itself or any of the lead wires, so getting a regular reading makes sense to me. This leads me to think the ferro fluid is somehow increasing the resistance of the coil and causing other fun stuff.
The next step now is to clean out the ferro fluid and see how the tweeter performs without it. Well, this is a bit of a rudimentary method but, I took some paper, and stuffed it into the gap and just kept wrapping it around in there until the paper started coming out clean. Not the, ahem, best way to do it but it worked. OK so now, the real test. I put the diaphragm back onto the magnet (which was simple by the way), put it all together and fired up some music.
Well now. This sounds much better! I did a comparison to the left speaker which still has the ferro fluid and no doubt about it, it now sounds rather dark and a bit midrange strong. Huh. Well, without the ferro fluid in there it's definitely going to cause the tweeter to handle less power, but as long as I'm very careful, I think it should be okay for now until I can source some proper ferro fluid.
The reason I am putting this up is because I know there are many of you whom have Kef speakers with the T33. I think it's imperative to get this ferro fluid changed, there's absolutely no doubt about it. It's as imperative as recapping the speakers. However the tweeter is more important because, if the ferro fluid hardens enough it could actually separate the coil. Not good. For those of you out there who have this tweeter in your speakers, I highly recommend at least cleaning out the ferro fluid and being very liberal with the volume until you can get some proper ferro fluid. I think having no ferro fluid is a better situation than having the goop harden up and ruin a tweeter.
If anyone has any details to add, please feel free, but I think this is the best bet until a solid solution (actually, not so solid in reality
) can be figured out.
