I've been restoring my new (to me) SX-1010. When I got it the stabilizer board needed refurbing and then I also proceeded to replace all the caps (except the 2 PS caps) and replaced the indicator lights with LEDs (but not the dial or meter bulbs).
Here's the problem; when I engage or disengage the tone control bypass toggle switch or the low pass filter or attenuation (but not the high pass) I get a 'pop' and then it goes into protection for a moment. If the tone is bypassed but I press one of those 2 switches I still hear a 'pop' but it doesn't go into protection (though those functions still operate). Before and then once it resets the rig appears to sound fine. This also occurs regardless of the position of the tape monitor switches so I'm guessing it's something after that, probably in the control amp. I'm thinking I should upgrade the transistors in the control amp but then that's just throwing parts at a problem and isn't the best diagnostic procedure. I adjusted the power amp voltages as per the service manual.
I injected a sinewave through the aux input and looked at the signal through my scope and the waveform 'jumps' when I click one of these switches.
I have another (electrically unrestored) SX-1010 that makes a bit of a 'pop' when I switch the tone bypass but doesn't go into protect so I'm guessing this isn't all that unusual a situation.
Thoughts?
JimB
Thoughts?
JimB
to make my wife happy but I really did it to optimize another system.
