Macaroon
I recently got a 2238B from eBay which was advertised as having a scratchy volume control. I've bought 7 or 8 receivers in the past year or so, most of which had scratchy pots and were priced accordingly ( I usually buy the lower-priced stuff due to my chronic brokeness). When they show up I pull out the Caig's and get to squirting—and almost always have successful results right away. I think my luck has run out.
This time, the volume and balance pots were in need, and after the first treatment the balance responded nicely. The volume . . . not so good. I've given it, probably, 10 good doses of DeOxIt over the past week, turning the knob a couple hundred times after each one. Still, it's scratchy. Actually, it's scratchy in the left channel and cuts out in the right. And more weirdness: if I let it play for an hour or so, it seems to get better. Much less scratch and very little cutting out.
It has other symptoms, too. The right channel might be a bit weaker than the left, and there's a buzz in both (like a bad-ground 60-cycle thing, but not too loud). Finally, tonight the single working dial lamp was pulsing, seemingly in sync with the channel cutting out. It's alive!!
Does it sound like this guy needs major surgery? And light you can shed is much appreciated.
