Redboy
a few good watts
A while back I pulled apart an old console that had an Olson tuner and a little SE 6BQ5 amp in it. I wasn't too jazzed about the tuner, and the thing has sat in my little workshop for awhile.
Today I figured I'd take a stab at making it a little more user friendly. The tuner / preamp fed into the amplifier via one of those octal plugs (what do you call those?). I picked up a 100K volume pot and some input jacks from the RatShack, and wrecked two drill bits trying to get through the THICK steel chassis (!). I didn't have any shielded wire around, so I just used some single strands of CAT5... bad idea?
Anyway, it worked!
Made music, anyway, and the volume pot seems to function properly. I'll hook it up to the Forte's later to see how noisy it is. None of the caps have been replaced yet.
I'm really thrilled, seeing as I had no schematic for this thing, and had to figure it out on my own.
Eventually, I might recap this thing and add a switch, fuse. I also want to put the little pilot light back in - I've got a jewel lens from another amp. Need new drill bits, first... :sigh:
BEFORE:
Here it is now...
Anyway, it worked!
Made music, anyway, and the volume pot seems to function properly. I'll hook it up to the Forte's later to see how noisy it is. None of the caps have been replaced yet.I'm really thrilled, seeing as I had no schematic for this thing, and had to figure it out on my own.
BEFORE:
Here it is now...
