With modern production techniques, the parts are not individually hand soldered. Rather, the parts are all installed on the board, and the board is dipped in a solder bath. No, not dunked, just the bottom of the board. It is all done at one time.
It is easy to have a bad solder joint. Sorry, that is the way it is.
But also a solder joint can fail for other reasons. For example, a receiver I have on my workshop now looking for a new home... it would play a few minutes to half an hour and cut off. Then cut on all by itself, and off.
Turns out that a high wattage resistor in a section of the power supply that fed +/- 12 v to power IC's in the preamp had a bad solder joint. It was probably good when it left the factory, but years of heating up, cooling, heating, cooling, finally fractured the solder joint, the wire lead loose in the middle of the solder. Finally, add a little corrosion due to age, movement from thermal expansion, and you have an intermittant connection. It happens. FINALLY I located the bad solder joint, desoldered with braid, removed the resistor, cleaned the leads with fine sandpaper, tinned, resoldered, and all is well. It has been test played for some time now with no problems.
