Here some pictures of the switches of a Sony TA-E88 or TA-E900, taken while disassembling them for cleaning.
One module.
The module disassembled.
You do not need to take the modules out of the housing for cleaning. You can just remove the bottom plate for cleaning.
Note there are two types of switches with different switching characteristic. So do not confuse them (well if done so it will probably be no disaster).
The "switch" before cleaning
... and after cleaning.
It is some work doing this for all these switches, but it is worth doing it. You will hear the difference!
I did not use any desoxit like stuff, as this removes material from the switch. I cleaned them in a electrolytic way. In a first step with silver-electrolyte the corrosion (silver sulfide) is reduced back to silver and some additional silver is put on the contact. Then as protection for further corrosion (for a while) I proceeded with a layer of gold.
One module.
