Hi,
Just wondered if anyone could help with a baffling fault that has been causing me some sleepless nights!
When I first recieved the amp, the symptoms were no output except a mild humming on both channels, and an unlit fuorescent indicator.
Subsequent investigations revealed two faulty electrolytic smoothing caps (the big expensive ones, R1 and R3! One of them had been replaced with a capacitor TEN TIMES LOWER in value than it should have been, and the other was probably leaky). One of these had been causing low output voltage on one of the main power lines (not sure now which it was).
Having replaced those, the hum reduced considerably, and the voltage was back to 55V, but still no audio from the amplifier section.
I then found that transistor Q8 in the power supply was open circuit in one junction, so I replaced it. On re-applying power, the fluorescent indicator came on, but the replacement transistor self-destructed, along with Q4 and Q6!
So, that is the latest state of play - I know this is a very complicated machine, so repairs will take time and patience, but I really need to know what to do next, as I do not want to cause any more damage to the power supply.
Any help would be gratefully received!
